Old 09-01-2011, 12:47 PM
smacaroni smacaroni is offline
Are you haunted by the ideas of a dead engineer or bean counter's pennies saved?
Remember the Budweiser Commercials "Real American Heros" and "Real Men of Genius"?
http://www.google.com/search?sourcei... en+of+genius
I do.
Also, last week while trying to partially unmount my gas tank, I was haunted by the decision to use a loose bolt instead of a stud, two of them mind you, to hold one corner of the gas tank. Since the bolt can turn freely, there's only one way to loosen it without damaging the threads, somehow get a ratchet and socket on the bolt head, then turn the nut. Or damaging the threads, grab on to the 2" long shaft and turn the nut.
What do they have against captive nuts? I salute you Mr. No Captive Nut Ever man!
Most fasteners are SAE, but not all! Here's to you Mr. nonsensical Metric Fastener Sprinkler.
And who could forget the guy who put an extra hole behind the grill where you'll certainly set an expensive tool or an uncommon nut or bolt while under the hood that will then roll into it and fall behind the grill? Where it will likely stay until the grill is removed before it's found.
Thank you random hole man.
I'm sure you've recently experienced a monumentally awesome decision by someone at AMC, post a tribute to him.
1982 Wagoneer LTD, Slushbox, I6 w/ 4.0 head, Explorer rear spring, 4.0 timing set/cover and backwards fuel gauge. How many gallons per mile do you make?
Proper grammar dictates the question is "may I borrow your BFH?" To which I answer "yes, you may, no take the bigger one, you'll need it".
Old 09-01-2011, 04:24 PM
Me and Honcho's Avatar
Me and Honcho Me and Honcho is offline
To the engineer who decided my Waggy would get a 2.73 gear ratio.
Here's to you "Mr. I never drive anywhere but the Interstate highway man".
79 J10 Honcho
91 Grand Wagoneer
82 CJ5 Renegade
Old 09-02-2011, 04:18 AM
HOOT's Avatar
HOOT HOOT is offline
Here's to You Mr. Good Buddy, Leisure suit wearing Engineer. Only you could design a option package for all your wanna be trucker pick up drivers. Give it a cool name, "That's a big 10-4 thar good buddy" and make the CB Radio an option....
"Here's your sign" ......
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 09-02-2011, 04:31 AM
HAR! Agree!
Old 09-02-2011, 04:42 AM
Mars's Avatar
Mars Mars is offline
Here's to you "Mr. Power Tailgate Wire Router!"
Wannabe Fabricator
Grumpy on a good day.
Old 09-02-2011, 04:49 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
Here's to you Mr underhood meat hook of death guy!
'65 J2000
Old 09-02-2011, 07:07 AM
OH,OH, heres to you Mr no rear axle shaft solid retainer designer...
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 09-02-2011, 07:18 AM
draglink's Avatar
draglink draglink is offline
Here's to you Mr Spring-under designer guy
Im used to Ford trucks(SOA), this whole under thing makes NO sense to me at all!!
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
Old 09-02-2011, 08:39 AM
hummer010's Avatar
hummer010 hummer010 is offline
Yeah - he's one of my fave's.
I also like Mr. Randomly place fusible links through out the vehicle.
and Mr. make sure the cab leaks in several places.
68 j3000 327/T18/D20 Work in Progress
Old 09-02-2011, 09:59 AM
Mikel's Avatar
Mikel Mikel is offline
It's actually a great setup. Flexy, smooth riding...
1969 M715 6x6
1963 J300 Swivel frame
Old 09-02-2011, 10:00 AM
Mikel's Avatar
When I went to look at my future '78 Cherokee at the seller's home, I tried to open the hood and it whacked my thumb . It was a sign of things to come!
1969 M715 6x6
Old 09-02-2011, 10:25 AM
Schlagger's Avatar
Schlagger Schlagger is offline
Here's to you, Mr. Pull The Gas Tank Skid Plate To Remove The Leaf Spring! You are a true American Jackwagon!
1979 Wagoneer QT 360 4" BDS Lift
1979 Cherokee Chief QT 360
1968 Jeepster Commando 4" HC Lift
2006 Honda Shadow Aero
1986 Honda XR600R
1984 Chevy 3500 Box Truck
Old 09-02-2011, 01:29 PM
86gwrhino's Avatar
86gwrhino 86gwrhino is offline
or designing an open diff tcase with vacum shift...
thank you mr. mall crawler tcase designer
'86 Grand Wagoneer
Chevy 350 TBI
Rhino grill
rusty's 4in all spring lift
'67 (i think) M715 all stock w/pto
Old 09-02-2011, 02:03 PM
SNO*MAN's Avatar
SNO*MAN SNO*MAN is offline
Hail to the chief of- place a hole where you don't need or want it designer with the one where you do and there isn't one hole-tard.
The one behind the grill hood latch brilliance? WTH?
1989 "KRONK"
Detroit front/rear 4.27 gears
Ramsey 9000 modified bronco winch bumper
Built 360/ 700r w/ 241c Lokar floor shifter
Hydro-boosted brakes
20" wheels w/ 35" Toyos
15" Welds w/35" Uncut mud boggers
Dual Ram Air /MSD TFI Ignition /Dakota Dash
www.fastfinishor.com
www.fastfinishor.blogspot.com
www.facebook.com/fastfinishor
Old 09-02-2011, 02:08 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Here's to you Mr. 20 bolts of random size and length just for a couple of accessory brackets engineer guy.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 09-02-2011, 02:18 PM
Billygoat's Avatar
I laugh at these and agree most are less than brilliant ideas on the designers part - however, I would rather wrench on a FSJ than most newer cars...
How about a salute to lets put in a smathering of Torx head bolt guy!
Old 09-02-2011, 02:43 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
What about Mr. Well nuts to attach the luggage rack to the roof guy or Mr. One off rear wiper motor guy.
Originally posted by Ristow
i bet it was Simon....
Old 09-02-2011, 03:41 PM
Pmoreau's Avatar
Pmoreau Pmoreau is offline
Lets not forget the wiring. From all of you who have had a fire, why don't you give it to Mr. rout the alternator wire througfh the dash.
Paul
'70 J4000
Old 09-02-2011, 03:48 PM
I'm quite fond of Mr. let's stick the roof insulation on bare metal and paint around it.
(You can beat Mr. Meathook at his own game.
Tennis ball with a slit cut in it saves a lot of scalp.)
Old 09-02-2011, 03:57 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
LOLOL
I agree with all of these, but could you imagine what we would come up with if we were talking of a Chevy Vega???
LOLOL
WH
Herbina 1987 Grand Wagoneer
