Old 08-26-2011, 09:35 AM
Tchat Tchat is offline
Drip Rail Molding
OEM drip rail moldings for the GW are impossible to find!! What is everyone using for replacement drip rail?
Thanks for any help!
Old 08-26-2011, 09:45 AM
Tripwire's Avatar
Tripwire Tripwire is offline
Paging DR. Crist
Abort? Retry? Ignore? >
Old 08-26-2011, 09:50 AM
80CHEEF's Avatar
80CHEEF 80CHEEF is offline
ive been looking for these for some time as well. seems like a impossible hunt
-Nick M
1980 Cherokee Chief- AMC 304 4" lift
2007 Rubicon 2dr- Old Man Emu HD lift 35" BFG KM2
Old 08-26-2011, 09:59 AM
ajminla ajminla is offline
Older Wag Stainless
My favorite solution is to find an old wagoneer that someone is parting which had stainless steel drip moulding. Then polish it up.
It's a bit pricey sometiimes but they are out there and it looks way better than the crappy plastic that our late models have.
'89 Grand Wagoneer
Black with Sand Interior
"The Other Woman"
Old 08-26-2011, 10:04 AM
80CHEEF's Avatar
how do you go about reattaching them?
-Nick M
Old 08-26-2011, 11:03 AM
BotterbrodtGE's Avatar
BotterbrodtGE BotterbrodtGE is offline
Stainless Steel molding
Went to the local yard and grabbed the drip molding off an older Cherokee. Saw one wag that the metal part of the roof for the drip molding was 6" shorter than the actual roof an mine went the whole length so I'd measure them to be sure. Just an FYI. They polish up quickly and make the truck look a lot better to someone that knows these things. Basically to take them off you carefully pry out the bottom. They're basically an L shape with a hook on the top. When installing; hook the top to the roof and push on at the bottom and work your way down carefully and slowly
1990 Stock for now Grand Wagoneer
U-993
Hey there Yohoo, fix yourself!!
My jeep
http://www.ifsja.org/forums/vb/showt...highlight=1990
Old 08-26-2011, 01:46 PM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
GW: Drip-rail Molding
I concur with what has been posted. In the end, a good GW/IFSJA friend (Mr. Steve Tripwire) acquired a set of stainless off an older GW; Of which I then had restored.
There are some nice trim folks that have both the half-round and L-shape that would work. Look here for examples: http://www.trim-gard.com/index.asp.
Don’t take my word for it… Here’s a note from Mr. Norbert, himself, at grandwagoneer.com:
Sent: Friday, December 17, 2010 6:49 PM
To: Crist D. Clapper
Subject:
Drip-rail Molding
Hi Crist,
I'd be happy to answer that for you.
I use both. I still have a decent supply of the OEM rain gutter trim and also can restore the original pieces to about 90% of new appearance.
However, depending on the customer's wishes and on the color of the Jeep, the larger, slightly more pronounced half-round or slight teardrop "chrome" trim with acrylic adhesive lends a more dramatic visual impact and more contrast with the roof. It is also less brittle and more flexible, making it less likely to get the stress fractures and spiderwebing that appears on the factory trim within a few years. I give clients a choice after presenting the advantages of each and letting them look at the difference in cosmetic appearance.
Sincerely, Norbert
1990 Grand Wagoneer:
1987 XJ Wagoneer Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
Member, FSJ Prissy Restoration Association (FJS-PRIS)
Where can I get new drip rail chrome? kevinp661 General FSJ Discussion 67 02-27-2011 09:15 PM
Help removing chrome drip rail trim F. Townsend General FSJ Tech 12 09-25-2010 05:52 PM
drip rail Q's? manimal General FSJ Discussion 3 12-28-2008 02:56 PM
roof drip rail rust hogwagon General FSJ Tech 4 05-23-2004 01:58 PM
