Will the center caps from my 87 GW fit on slotted rims off a '76 Wagoneer?
center caps
I don't see why not. As long as the slotted '76 rims have the same screw pattern for the screws to hold the cap on as the rims on the 87, it should be fine. Other than that I don't think the bolt pattern on the rims or axles changed at all, so bolt pattern shouldn't be a problem.Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Work in progress Miles: Less than 140K (as of the talk with the original/previous owner) "The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
