I've already got this project underway, as you can see. I've been a long-time fan of IH engines and Wagoneer bodies/style, so I can't think of a better combination (for me). And I figure if a 345 is good enough to push dump trucks around, it oughta drag the Waggy around just fine, too.
I have the engine, tranny, and t-case ready to pull from my 85 Waggy, and the the engine from my Scout nearly ready to pull. I dropped off my TF727's at the shop last week to have the AMC tailshaft and adapter installed in the IH tranny. From what I understand the Waggy power steering pump and alternator will bolt up to the IH brackets. The motor mounts for the 345 are super simple and those for the 360 unbolt from the frame, so it looks like fabbing some new ones should be a pretty clean cut deal. I'm probably going to take a few days after pulling them to clean up the 345, install new oil seals, valve guide seals, and a fuel pump, before dropping it back in. My biggest hurdles are going to be adapting the radiator to the IH engine, getting the exhaust system modified to hook up to it, spare time, and good weather. I'm really excited about the whole thing, though.
Here are a few more pictures of odds and ends with this swap. There will be more as I go.
