Will a dual diaphragm brake booster from a 86+ GW bolt up in place of a single diaphragm booster in a '79 Cherokee? The reason I ask is because I was going to use a dual diaphragm booster from a '77-'79 J-20 but the part literally does not exist anymore. All the parts places require you to send your old dual diaphragm booster in and have it rebuilt then sent back, and, well, I don't have a dual diaphragm booster to send in. I did notice however that you can still get dual diaphragm boosters for the Grand Wagoneers but it is a different part number than the ones for a J-20. I know they used different master cylinders in the 80's FSJs but can the boosters still be swapped? If it is a direct bolt on swap that would be primo.
And NO. Hydroboost is NOT an option.
Sorry for the long thread
