Today I was driving the Wag after I already drove it once. I turned into my parking spot and I heard a strange lound "pop" sound. The first thing I thought is Tie-rod, great. I had someone turn the whell side to side while I looked at it, and it sounded like it was coming from the bumper!!!! So now I am thinking steering box is jacked up because it is the only thing attached to the frame. I am worried about driving it home. Thanks.
Strange and sudden popping sound while turning?
When's the last time you tightened the u-bolts for the front springs? I'll bet if you tighten them, it'll go away. It's a standard noise for an FSJ, and was installed from the factory at no charge!Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
?Freedom is never more than one generation away from extinction? by Ronald Reagan.
Loose U-Bolts... hmmm... I've been chasing the same kind of popping/thumping sounds under my wag too... I'll have to crawl under and crank those bad boys down a turn or two... Thanks Lindel!!!Wudreaux the Wonder Wagon<BR>\'78 Wagoneer<BR>401 TH400/QT/Low Range<BR>TFI Upgrade<P><BR>Bone stock... but not for long!!!
I had that same noise, Yep, spring eye bushings. Installed a set of poly bushings 8 years ago and haven't heard that noise since79Cherokee Chief<br />4\" BDS Lift<br />Custom Bumper <br />33\"x 11.5\" x 15\" BFG All-Terrains"<br /> T.H. 400 B.W.1339 Quadra Trac <br />Mile marker 16% O.D.part time kit<br />360c.i. Edelbrock pkg.<br />MSD ign. & coil <br/>Bored .030 over<br />Tri-Y headers<br />stainless steel exhaust<br />mustang seats<br />Holley 4bbl
Yep, same thing here...heard a popping sound when Id turn into my driveway and wasnt sure what the cause was. It disappeared when i installed a 3" lift kit; new springs/poly bushings did the trick!
bighouse<br /><br />1983 Wagoneer Limited \"Big Wood\" <br /> 360,727,229<br /> 3\" RC lift-32x11.50xR15\'s<br /><br />1983 Cherokee Laredo \"The Hulk\" <br /> 360,727,229<br /> (parts)
