FSJ VS FORD Rear dana 60 ???
  • jeepsohigh
    • Feb 05, 2005
    • 142
    Is there a difference in a rear J-20 dana 60 and a ford dana 60 exept for the spring perch placement? how does the width compare?.
    Thanks
    1982 3/4 ton Honcho sportside
  • #2
    Don't know the answer to your question, but the Dodge (70's-early 90's) Dana 60 rear is a bolt in for the Jeep.
    • wickedwagon767
      • Dec 26, 2005
      • 1932
      Chevelle guy is right. The Dodge is a bolt in
      Most of the J20 rear Dana60's and Ford Dana60's had 30-spline axleshafts. The 1-ton HD Ford 60's had 35-spline shafts.
      Other than the J20 Dana60 being a couple of inches narrower in WMS they are very identical from the mid 70's through the early 80's
      • KaiserMan
        I got the Willys....
        • Jun 21, 2005
        • 8704
        J20 D60's will also have a 7 bolt backing plate/flange vs. the 4 bolts on the Ford.
        Dodge D60's only bolt into Wagoneers and Cherokees. The perches still need to be moved to fit J-Trucks.
        1971 Gladiator
        • #5
          I was unsure on that part, thanks.
