As far as fuel mileage goes which kit from Howell would produce better results? The offroad kit or the California kit? I'm planning on injecting one of my 258's and am not sure whether or not to leave all of the emission stuff in place as there is no emission testing in the county I live in.
Howell TBI, emissions or not?
I'd go with the CARB certified kit. You never know where you'll end up moving around to and it'll be better to have it and NOT need it versus the other way around. I doubt mileage will be any different. Heck, it might even be better with the emissions version.Ethan Brady
www.bigscaryjeep.com
He's got a 258. Isn't the CARB legal version basically a copy of the Mopar fuel injection that was available on later motors?Ethan Brady
Originally posted by FSJ GuyHe's got a 258. Isn't the CARB legal version basically a copy of the Mopar fuel injection that was available on later motors?Last edited by tgreese; 11-02-2011, 01:56 PM.Tim Reese
Originally posted by tgreeseNope. The Mopar fuel injection kit is based on the multiport (MPI) system used in the Wrangler. The Howell system is a throttle body (TBI) system using GM parts used on the 4.3L Chevy V6. Completely different. The prices are different too - the CARB approved Howell kit is about $1400, and the Mopar kit, also CARB approved, is over $2000 (likely well over now; I have not looked at the price in a while).Ethan Brady
Originally posted by babywagFor a 258 I'd get a complete system off an XJ w/ a 4.0 including the head.
Could probably buy 3 or 4 set-ups, for the price Howell wants.
From what I've read about them the wiring is minimal & easy.Tim Reese
True about CARB sticker, but you're using OEM approved parts.
Even in CA they would slap a sticker on it if it passed sniffer & visual.
I know a couple CJ people that have had no problem with the smog police after converting.Tony
I'm leaning towards the XJ system as I have two 258's that I'd like to covert without killing the wallet. One is in an Eagle with a functioning carter BBD and associated sillyness and the other in the J10 with nothing original. The thing that scares me more than anything else is the wiring.
For the FSJ don't you need to run HB to clear the 4.0 intake? Never really looked into it but what is the cost like?You know it's bad when your car's on the EPA's 10 most wanted list!
'88 GW
'77 J10 Golden Eagle 401
Originally posted by babywagHB is pretty cheap if you go used parts from Elliott, and buy new hoses etc.
I think I spent a little over $200, best upgrade money can buy for an SJ.1You know it's bad when your car's on the EPA's 10 most wanted list!
'88 GW
