I have been fighting this demon for about 6 months, and I am about at my whits end. most of the time it starts and every thing works fine. some times when I turn the key to the start position i get nothing. I mean nothing. No power in the jeep at all. Not to the radio, the lights, nothing. No power running out of the battery at all. I let it sit over night, fires up fine the next morning. Last time I was driving, this happened while it was running and in gear, just lost all power. Parked it, came back the next morning, working just fine. I have replaced the ignition mod, the starter sol, and run just about every wire there is to run. I keep thiking it must be a grounding issue so nothing works, but I am not sure. Could use some advice.
Electrical problem
TIPICAL JEEP
The other two thing I would check are the batt + at the solinoid, and the connections at the ammeter, if it has one. You might consider the fact that the batt might hav a broken post internaly. "YOU'L HAV THAT"Last edited by [email protected]; 01-10-2008, 10:00 PM.65 Kaiser wagoneer 2door Panel AMC Vigilante 327, T-98, D-20, closed knuckle, D-44, on BFG M/T 35s MY DD
79 Cherokee S Desert Camo, project waiting for trans from green
78 Cherokee S Green, salvage heap, w/ blown 360, stuffd full of lots of extra FSJ parts.
another thing to consider is the shifter column. it may need to be in a perfect position to work. i had the same problem, i considered it as a antitheft device, it had to be it one spot to allow the key switch to work.
also the above advice is good, you should check everything, grounds, connections, check voltage when running and not running to make sure your charging.Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
The battery still reads hot when it is doing this. I have by passed the ammeter in the dash, I have checked the positive cable to the sol. I will replace the two main ground cables. I guess the next time this happens I will check the ignition switch. Thanks85 Grand Wagoneer
1.5\" AAL\'s
MSD/TFI Ignition
89 Grand Wag
Also check your fusible links. They may APPEAR OK but may have broken connections inside the insulation.Ethan Brady
www.bigscaryjeep.com
Originally posted by shadowjeepanother thing to consider is the shifter column. it may need to be in a perfect position to work. i had the same problem, i considered it as a antitheft device, it had to be it one spot to allow the key switch to work.
When I swapped my auto to a manual I had the old shifter on the column. If it wasn't right it would do the exact same thing. Possibly you left it went out in the morning grabbed the shifter to make sure it was in "Park" and it fired because you touched the shifter again.Places to Wheel in the Southeast
Originally posted by Topgun2moI would think boxing would limit the amount the frame could flex over obstacles which I think IMO would be a bad thing. I would think you would want all the articulation possible.Originally posted by johnny019I'm not saying lockers don't improve the performance of your rig, just that they're overrated.
OK, lets break this down some. You saidOriginally posted by shadowfax101some times when I turn the key to the start position i get nothing. I mean nothing. No power in the jeep at all. Not to the radio, the lights, nothing. No power running out of the battery at all.Originally posted by shadowfax101Last time I was driving, this happened while it was running and in gear, just lost all power.Mark B. Jones
Originally posted by GrandWag&PrixActually, now that I think about it, that could be either awesome or really terrible.
