I?m currently driving my ?81 Wagoneer 258 / 727 / 208 on a road trip through Mexico. Today while climbing up and down a few passes, my transmission started to slip. I immediately pulled over, check the transmission level and saw that it was a bit low, so I added 2 quarts on the spot which brought it up to level. After that I started the Wagon up, let it idle in neutral for a few minutes to circulate the fluid, but when I went to put it in gear it would not engage. Nothing. Park does lock up, but Reverse and Drive both act like neutral.
What should I look for? Does anything come to mind other than a replacement / rebuild? I?m 99% sure it?s not the transfer case. I?ve also verified that the shifter linkage is actually turning the arm on the transmission. About six months ago I did replace the filter / fluid (which look clean then) and I?ve put a few thousand miles on it without a problem. Any ideas?
