Old 09-13-2006, 11:51 AM
Gambler68's Avatar
Rabble Rouser
Post your links for Archive material
look down in Site Suggestions, I braved the idea of getting the archives updated, here's your chance. Give our friendly mods a hand picking out some good ones.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 09-13-2006, 01:12 PM
While you are at it try to list the appropriate section it belongs in.
Also, if there are extraneous posts/replies inside the post that do not lend themselves to the overall theme of the post I'm going to be editing them out to save space/time/etc.
Thanks,
Old 09-13-2006, 04:18 PM
testuser's Avatar
testuser testuser is offline
gambler....great idea.
tad....thanks for following it up with decisiveness =)
I'm going to make this thread a sticky on top of the forum.
IMPORTANT
Only reply to this thread if you are:
1 - Suggesting a specific thread with a link to it
2 - Give a destination (category) to which it belongs
3 - Don't post links to all of your own posts for the last 3 weeks
Thanks!
Old 09-14-2006, 01:20 PM
caionneach's Avatar
caionneach caionneach is offline
Exclamation I vote the $15 ammeter/voltmeter write-up
$15 Ammeter/Voltmeter Retrofit write-up moved to Archives under "Electrical"
Thanks Kenneth,
Tad
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 09-21-2006, 01:14 AM
The brake upgrade is good, long as all the BS gets whacked....
Lots of good TBI info a while back as well.
I'll see if I can find the link(s)...
TFI would seem to be a good one, since it comes up just as often as SOA.
The turbo project from rustywagoneers_com??
http://www.ifsja.org/forums/vb/showthread.php?t=46107
A: Big Brake post, I think I got most of it cleaned up.
B: Someone smarter than me needs to go through the TBI/TFI stuff.
C: Someday when it is done I guess.
Thanks Tony,
Tad
Old 09-24-2006, 11:18 AM
Rogue's Avatar
Rogue Rogue is offline
360 AMC
http://oljeep.com/gw/alt/edge_Alternator_Theory.html
Joe Guilbeau's alternator tech article
Old 09-26-2006, 08:09 PM
Sorry, I have not had much time lately, all are under cosideration except I do not think I can archive Joe's stuff rightfully since it is not posted on this site (he may actually have a post here IIRC - I'll look), but that's so easy to find one would be hard to miss it.
Old 10-10-2006, 10:36 AM
pb's Avatar
pb pb is offline
Rear Main Seal Replacement moved to Archives under "Engine".
Thanks Paul,
Tad
Also, what about the ball joint write up out there?
See post below.
Paul
1975 Wagoneer DD
Old 10-12-2006, 08:01 PM
That's nice, thanks.
The best Ball Joint write up I know of is by J10Mike and on his site...
http://12.29.16.230/mmimages/index.htm
...I tend to look at it this way.
If I link something, as opposed to posting it (I mean the pictures and everything) I look at it as propritary material. I would prefer folks not include that in web archives (I know I can't stop that and I do not mind if folks pass it on).
I do talk with Mike often and will ask him, if he's fine with that, we'll setup a post, like Waynes. One post, info presented, closed and archived.
Or did you have another Ball Joint thread in mind?
Old 10-13-2006, 07:07 AM
Grimjaw's Avatar
Grimjaw Grimjaw is offline
Low-buck H4 Headlight Conversion
Low-buck H4 Headlight Conversion moved to Archives under "Electrical".
Thanks Grimjaw,
Tad
Does anyone have Bronco gas tank writeup from RiverBeast's site?
I saw it last on that FSJ Magazine site.
If someone can grab it all and copy it up nice I do not think Todd would mind at all.
Ivan the Terrible
1979 J10 360/400/bw1339
Old 11-07-2006, 01:25 PM
Rogue's Avatar
360 AMC
an excellent written post with good information
http://www.ifsja.org/forums/vb/showthread.php?t=58170
Yes it is Jeff but I am not going to bother.
Eventually JYG will realize he still has pic's up for that and will take them down, it will then become useless.
I would suggest folks go read through it and make some notes before that happens.
Old 11-09-2006, 10:29 PM
Kevin718 Kevin718 is offline
GW Wheel Bearing, Spindle Bearing, Rotor Replacement - Information (Many Pictures), moved to Archives under "Drivtrain".
Thanks Kevin718,
Tad
1991 Grand Wagoneer
360/2150/727/NP229/3.31
Old 01-12-2007, 07:56 AM
Rogue's Avatar
360 AMC
Closed knuckle inner and outer oil seal replacement-write up, moved to Archives under "Drivetrain".
Thanks Jeff,
Tad
Old 03-19-2007, 03:41 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
Is there any way to get the archives to be searchable in forum?
'10 Chevy Silverado 5.3L - The DD.
'81 Jeep CJ-7 Laredo
Texas A&M Offroad
Old 03-19-2007, 04:06 PM
Rogue's Avatar
360 AMC
archives can be searched by selecting advanced search and selecting appropriate criteria
Old 03-19-2007, 04:08 PM
CustomWag's Avatar
CustomWag CustomWag is offline
Quick way to tell if your oil leak is REALLY the RMS
http://www.ifsja.org/forums/vb/showthread.php?t=66178
Done:
Thanks,
Tad
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 03-19-2007, 09:02 PM
TexTJ209's Avatar
Maybe I'm just retarded...but you sure about that?
Texas A&M Offroad
Old 03-22-2007, 10:34 AM
scantar's Avatar
scantar scantar is offline
This one for sure belongs somewhere...either archived under suspension or tech library...
http://www.ifsja.org/forums/vb/showthread.php?t=66430
Steve
Done:
Thanks,
Tad
Old 07-12-2007, 07:46 AM
backpack09's Avatar
backpack09 backpack09 is offline
http://www.ifsja.org/forums/vb/showthread.php?t=72082
Moved to Electrical Archives - 7-22-07
Thanks
Dan G
91 GrandWag
MSD Mag Dizzy, MSD 6A
Old 08-12-2007, 11:24 AM
Rogue's Avatar
360 AMC
http://www.ifsja.org/forums/vb/showthread.php?t=73360
Done, Thanks
