Old 05-18-2012, 07:25 PM
Jeeplove Jeeplove is offline
CA Diesel Question
Ok, so first off let me start by saying I live in Southern California, I love Diesel's and I love Jeep's.
Now for my query.
I was wondering if it would be legal for me to put a newer Dodge Diesel(24v) and shove it in a Grand Wagon here in CA. Would everything be kosher?
Anything helps.
-Chris
Old 05-18-2012, 07:35 PM
dweyler dweyler is offline
Noob!
CA Diesel Conversion
From what I understand about CA clean air regulations as long as you can pass the NOX and exhaust gas test based on your year of vehicle there should be no problem. The main problem with diesel is that it will emit a certain amount of particulate matter and smoke if not tuned correctly. That could scramble the passing of the smog test. It also depends where your reside in the state as well. Major areas have tighter emissions regulations than rural areas. I would find out what your regualtions are based on your address and the tag on the engine you want in your wag will tell you if properly tuned what emissions standards it meets. If you have any qestions just pass one along here. I will be glad to help. I know on heavy trucks entering california they can no longer transit in state if they have any older truck then 2004 emissions-which was the first year of EGR systems on trucks. Check the regulations and go from there, its better to find out first then build to pass then to get done and fail after all that work.
Old 05-18-2012, 07:52 PM
This is exactly why I asked. I didn't want to throw a ton of money and work at something that I couldn't enjoy when finished.
But in theory it can be done correct? With a 24v that is?
Old 05-18-2012, 08:23 PM
billyj7175's Avatar
Might be different than gas conversions, and possibly the laws have changed, but back when I was stationed in CA (late 80's-2002), the conversion has to be the same year, or newer, and all applicable smog equipment from the donor vehicle has to be in place.
IIRC, there were some GVWR limits on swaps as well.
Hopefully one of the more current CA folks can chime in to verify or correct me.
83 J-10 Jeep "Oscar"
360/727/229
Old 05-18-2012, 08:41 PM
I hope they come in and help, i would really love to do this.
Wish I had a Grand Wagoneer.
Old 05-19-2012, 12:20 AM
There is an 800 number on the BAR website, call them and tell them you'd like to talk to your local smog referee about an engine swap.
*IF* it's the same guy, he was pretty up front and will tell you yay or nay.
He's told me nay twice, and yay once.
Nay on 1994 H1 Hummer 6.5 Diesel - heavy duty engine not allowed in light duty truck.
Nay on Cummins 4BT from bread truck - same as above.
Yay on GM TBI swap, not an actual engine swap, but if it passed visual/dyno, he said he would slap a sticker on it.
EDIT: Be sure to use a pre-1998 engine too IIRC anything 1998-up diesel still needs to be smogged.
Old 05-19-2012, 10:56 AM
I don't see why they would have said nay to the first two swaps you had plans for as you were well under the GVWR limits. I will have to talk to or get real friendly with the referee so he will let me do it.
I also don't mind that I would have to smog the engine, I really want the power/torque/quiet aspect of the 24v.
Old 05-19-2012, 11:53 AM
Kevin armstrong Kevin armstrong is offline
There used to be a little brochure in the dmv offices that stated all the requirements. I bet you can find in online.
Old 05-19-2012, 12:44 PM
Do you happen to recall what it's called?
Old 05-19-2012, 02:21 PM
Smog referee is the final word, just call them. You'll know exactly what you'll be facing with your swap.
DMV just pushes paperwork and is clueless about engine swaps.
Any DMV brochure would be info obtained by the BAR anyway.
If it's the same guy, he's more than willing to discuss the swap with you.
I talked to him 3 different times, he was very informative and helpful.
Old 05-19-2012, 02:57 PM
bruner1981jpce's Avatar
bruner1981jpce bruner1981jpce is offline
X2 on talking to the smog referee. My dad and I have looked into different engine swaps for my Jeep and his old plymouth, and the basic requirements are:
The engine to be swapped in must come from a vehicle of the same weight class
It must be an engine from a newer model year vehicle than the vehicle it is going into
It must be a bigger engine ( no 4.0 swap for me)
It must have all the smog equipment on the engine that it came with
Supposedly you also have to keep the same type of transmission with the engine (if it came with an automatic, it must stay automatic; same with manuals. when my dad recently got his plymouth smogged, the guy said he never checks to see what transmission is in it, so i guess it depends on the shop)
hope this helps!
Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Storage Miles: Less than 140K (as of the talk with the original/previous owner) "The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
Old 05-19-2012, 04:56 PM
Alright, so the referee it is. Thanks for all the help and wish me luck!
Old 05-19-2012, 05:10 PM
hope this helps!
You could probably get away with a 4.2 or 4.7 right?
Old 05-19-2012, 05:41 PM
I've got a 4.2 (258 ci) as it is. Anything bigger than that would be ok as long as its newer and from a vehicle of the same weight class.
Andy
Old 05-21-2012, 02:30 PM
manimal's Avatar
manimal manimal is offline
http://www.ifsja.org/forums/vb/showthread.php?t=151627
I just went over this with the ref. You CANNOT legally put in a diesel from a vehicle that was a higher GVW than your waggy....ie, 24v cummins..or even a 4bt for that matter. You CAN however put in a 6.2/6.5 from a 1/2t truck/suburban or blazer. OR you can do the diesel swap and goto a local AAA and fill out the statement of facts stating that it has been changed to diesel and they send it in, you get a new title and no more smog!
-Lance
Originally Posted by REDONE
Bring some wet-naps. I'm gonna lick everything you butt doesn't touch!!!!
Heck Yeah, I am an equal opportunity offender today and think we should all get bent.
Old 05-23-2012, 12:29 PM
Does this mean I COULD get away with the swap or would I still have to go with the 6.2/6.5?
Old 05-24-2012, 07:29 AM
dusty's Avatar
dusty dusty is offline
At the top of here is a sticky that says "Diesel swappers start here"
four posts down is a header that says
CA legality and Diesel swap issues/options:
right below that header is a link that says How to do a CA SMOG Legal diesel swap success
That thread was pretty extensive and covers all of this.
So make this straight forward answer both of these questions together when doing the swap.
your rig year is what year?
the engine you choose must be the same year or newer.
the GVW on your rig is?
The GVW on your donor rig must be the same or Less
So this means a 6.2 or 6.5 from a H1 or a 2500 pickup truck can not be installed in your 1/2 ton rig. those rigs have 8800+/- gvwrs and you probably have a 5600-6000 gvwr. their emissions standards are different and the engines came setup differently. any engine you choose you must retain all of the smog equipment so a late model 6.5 with a CAT the CAT must be retained for inspection.
Very few people have had luck with the statement of facts option as typically it needs to be visually verified by the agent that the engine is indeed a diesel. otherwise every guy with a jeep in CA would be claiming to have a diesel so they could slip in a V8 imeadiately after registration was done. it is doable, i didnt have to do a statement of facts i just rolled up in my f250 which had a 460 which now had a cummins and the dmv personel came out verified the epa sticker on the side of the engine stated diesel and was for my class of vehicle use (ie was not from a heavy duty (higher gvw), offroad or stationary engine platform and sent me on my way no smog ref or anything else.
Good luck.
I know on more than one case i might be guilty of keeping a $200 purchase, 6.2L from a light duty application around with the registration and vin to the original donor vehicle around for light duty swaps that i used to swap into a rig, cobble it in, have it verified by a ref, come home, rip it out and instal a 4bt. jsut make sure you run the 3" exhaust pipe and muffler as though you are going to run the 4bt so that the exhaust repair work is minimal once you cut the 6.2 loose. also a big long flex hose with straight water int he coolant system does sufice. none of the electronics other than starter and fuel shut off need to be hooked up. and two bolts can hold a set of more bomb proof motor mounts in place.
AMC 401 supporter
GO UM Montana Griz
cummins 6bta Diesel Wagoneer Project FSJeeper Diesel Swaps 24 05-14-2011 04:46 PM
DIESEL CONVERSION FZJ FAQ swedjeep General FSJ Tech 5 04-29-2008 10:19 PM
First Step down the Diesel Swap Path The PIG Smith Diesel Swaps 7 06-19-2007 12:34 PM
Question for Diesel experts Careful34 General FSJ Tech 18 12-18-2002 08:31 AM
anti diesel solenoid question Simontrips General FSJ Tech 2 03-09-2002 05:54 AM
