Anyone know if this style speed sensor would work on our rigs with the speedo cable and for a Ford TBI conversion? Seems to be for 90s Wranglers and Dakotas...
speed sensor (VSS)
Why You Might Want One. Without a Vehicle Speed Sensor (VSS) and the reluctor ring that feeds it signals, many engines including the Chevrolet TPI fuel-injected engines we specialize in will not run correctly and will not pass a smog test.Background on Our VSS Products. JTR Stealth Conversions began offering aftermarke
Check here for a 2K pulse sensor.76 Wagoneer 360/T400/QT
69 F100 SWB 390/5 speed
Originally posted by elskepticoDid some more digging and this won't work. GM TBI needs 2K pulses per mile. I think this other one I found is hall effect, not pulses.Tony
Holley Sniper ?
Hey guys anyone have any info on what the Sniper EFI would be looking for as far as a speed sensor ? Yep since I went to EFI my ?Cruise command? sorry love that description ....mine does not work. But did when I was carbureted.Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
An EFI install shouldn?t affect or make cruise control inop.
I?d check to make sure throttle cable/chain is connected, that vacuum line(s) are connected, fuse good, etc.
Cruise uses it?s own VSS, separate unit than GM TBI VSS.
I don?t believe the Sniper utilizes a VSS signal.Tony
The speed sensor for cruise is installed in the middle of the speedometer cable. Trace it from the firewall back towards the transfer case and you will see it.* 1981 stepside, 360, 727, 208, almost stock daily driver.
