Old 07-24-2012, 12:53 PM
8man's Avatar
8man 8man is offline
Blast media
Been using a grinder with different size and types of wire brushes to clean up the frame and get it ready for paint. There are spots where the brushes just won't go. I have a Northern blast rig and want to know what do you recommend for blast media? I will be blasting outside if that matters. Thanks.
Old 07-24-2012, 01:02 PM
For a frame I'd go with sand or use a needle gun.
Old 07-24-2012, 01:55 PM
Logans Run's Avatar
Logans Run Logans Run is offline
yeah... probably sand.
its cheap and a good choice for out doors.
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 07-24-2012, 02:54 PM
J20 project's Avatar
Use sodium bicarbonate/or blasting soda...it will help keep me in a job..
Simply melts away outside..
I wouldn't do it on the lawn tho.
J20 project
BP Drivetrain...........
775-537-7918
Old 07-24-2012, 03:42 PM
Sand is bad for your health. Silicosis. http://www.ncbi.nlm.nih.gov/pubmedhealth/PMH0001191/ Coal miners get a form of silicosis called black lung.
Slag (black beauty) may be the cheapest media that's not dangerous.
Old 07-24-2012, 04:08 PM
Gurinski's Avatar
Gurinski Gurinski is offline
I would say any form of media blasting is not good to inhale. Your not just inhaling the media but the material being removed also. In any case I would wear a respirator or good mask.
1991 GW TFI GM-icm 360 727 np229
Old 07-24-2012, 05:47 PM
serehill serehill is offline
Gone,Never Forgotten.
I'm pretty sure mine after checking from HF is soda.
Inside or outside it just vacums up. A resperator is require for all blasting no brainer. it works real well on frames & other needs.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 07-24-2012, 08:32 PM
Rod2's Avatar
Rod2 Rod2 is offline
Black beauty is a northern product and works very well for stripping paint without much stress on the metal; I have used it and like it.
I have used play sand from Lowes, also, that is pretty fine but is adequate for moderate dirt, paint,and rust.
You can check Eastwood.com blasting supplies and find a chart that they claim shows which media does the best job of doing each chore.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front with Warn Lock-O-Matics, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light, MileMarker 12,000 cradle mounted winch
Old 07-24-2012, 09:04 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
Tractor Supply has 50lb bags of sand blasting grit for about $7 and change. Works pretty good but wear ear, eye and mouth protection along with long sleeves, that stuff gets everywhere! Make sure you've got a good, dry air supply. Maybe it's just my setup (TSC siphon gun) but the slightest bit of moisture in the sand or the air and the gun performs like poo.
'65 J2000
Old 07-24-2012, 09:10 PM
ChiefBigB's Avatar
ChiefBigB ChiefBigB is offline
J20 project
If I'm not mistaken bi-carbonate is a milder media used for paint and is not that great for tough rust usual found on the frame. I would stick to sand, and use a respirator.
Old 07-24-2012, 09:14 PM
ChiefBigB's Avatar
also check on youtube to get an idea of how the different medias work. There are some good examples on there
Old 07-24-2012, 09:44 PM
Hutcho's Avatar
Hutcho Hutcho is offline
I used black beauty on my frame, watch it though cause there is different grits and my blaster didn't like the bigger stuff.
Formally known as "oilfieldtrash354"
"Grandpas" 1979 J-10 resto/mod-on hold for now
Preparing for Ouray 2013!!!!
Old 07-25-2012, 09:37 AM
Asphalt Cowboy Asphalt Cowboy is offline
You're correct in that soda is used to strip paint.
The reason for soda on body sheet metal is because it doesn't generate heat and warpage in the panel.
For a frame, especially with heavy rust and scale, silicon carbide would work best. It cuts more aggressively (faster) and the frame is heavy enough there's no need to worry about warpage.
Put a large sheet of plastic down to catch/reuse your media and don't forget your safety equipment.
1979 Wagoneer
360/TH400/ Q-Trac/D44's
31-10.50's on Truck Rallies
1965 Gladiator (model unknown)
T98, D20
D44 front D53 rear
slightly rusted, heavily neglected
Mouse in the defroster has
been evicted.
I might curse because roses have thorns,
Or I might rejoice because thorns have roses.
Old 07-25-2012, 09:52 AM
airman's Avatar
airman airman is offline
I use sand blast sand from Tractor supply.
Pressure blaster is the way to go but you need a good air supply.
15 CFM or more.
This is my set up. it keep the sand in check and eazy clean up and reuse the sand.
Andrew
1969 J3000 Dauntless 350, T15, D20
1970 CJ6 Dauntless 350 , T350, D20
1951 CJ3A in the wings
Old 07-25-2012, 10:05 AM
8man's Avatar
My wife is going to love my new sand blast booth! I like it and thanks for the input. I have to take a break from my frame, but should be back on it late August, I'll post up what I do. Thanks everyone.
Old 07-25-2012, 12:02 PM
CROCKETTBOONE's Avatar
CROCKETTBOONE CROCKETTBOONE is offline
Use dry ice. Wont damage the frame and there is NO CLEAN UP.
An opinion is just that, an opinion. A fact is a fact, and thought to be true. Please dont confuse an opinion with a fact. Life: Its sexually transmitted and always Fatal.
Old 07-25-2012, 01:49 PM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
I use Dupont Starblast media.
http://www2.dupont.com/Titanium_Tech..._H_60159_2.pdf
This product is 95% silica free. I think a 50 lb bag is between 9 to 11 dollars. This media works good with my HF blast pot.
I usually buy a couple bags at a time from this supplier: http://www.canfieldjoseph.com/abrasive-blast-media.php
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 07-25-2012, 02:00 PM
FYI: http://www.ifsja.org/forums/vb/showthread.php?t=126477
I want to sand blast some stuff Kevin armstrong General FSJ Discussion 11 02-27-2012 06:11 PM
Wheel restoration - Peeling Clear Coat temps425 General FSJ Tech 30 02-21-2011 06:12 PM
Media blasting in the garage - ya, I'm crazy gte901m General FSJ Discussion 8 10-14-2008 11:24 AM
Blasting media gte901m General FSJ Discussion 16 02-27-2008 05:10 AM
'65 Oil-type Air Filter Media 70sWagoneers General FSJ Tech 1 10-03-2006 11:47 PM
