A few weeks ago, my NP 228 gave up the ghost on the way home from work. Got my Jeep over to a friends house and we pulled the transfer case out and started tearing into it. Found that the rear output shaft bears blew up. We also found that the rear output shaft bearing on the rear half of the case was bad. I ordered a new case bearing, we had a spare transfer case that was cracked, so we plan on using the rear cone which has the output shaft I need, and I went ahead and ordered a new chain. I got everything back together rather easily, but when we put the new bearing in the back half of the case, it was extreamly tight going in (which is good). But when we put the rear shaft in, it keeps binding up. One of the spare cases we have appears to have a rear case half that is in good condition. I am thinking of just using this half as the bearing is in, it is good, and the shaft is already installed. Mt budy is worried that there might be small cracks in the rear half as the case took a pretty hard hit when the front half cracked. Is there any way for me to have the rear half of the case checked out for signs of cracks. I think at the end of the day, I am gonna use it and if I see leaks, I will source another rear half from somewhere else. Just wondering what peoples thoughts are???
Rebuilding my NP 228
The War Wagon: 1986 GW- SOA/SF on 33X12.50's, 360/727/NP228, CS 144 Alt, OBA
Wife's DD: 2012 Ford Focus SEL
My carbon foot print is bigger than your's.
WWW.SOCALULTIMATE4X4.COMTags: None
bump89 Grand Waggy, freshened up 360, 727, NP229, SOA/SF, highsteer w/ chevy knuckles, Dana 44's f/r, 35" Maxxis Big Horns, some rock rash and more to come....
R.I.P 87 Waggy
www.socalultimate4x4.com
Originally posted by PmoreauHave it magnafluxed.86 Grand Wagoneer Work in Progress
360 Toasted TF727 NP228
4" Lift
33x12.5x15" tires
"Shaggy" the Waggy
Yup, magna fluxing won't work on alum but if you want it checked talk to a good motorcycle shop. They're used to dealing with alum castings. They'll either recommend a good test shop or maybe a home use product.joe
