Old 01-06-2008, 10:51 AM
Mikel's Avatar
Mikel Mikel is offline
Post vs non-post articulation
Hello,
I'm considering moving the front springs in my J300 outboard (now they use the later style under the frame mounts), to the same spring spacing as the old post style mounts. I'm wondering how much articulation I'm going to lose by moving the springs outboard.
Do the non-post trucks flex noticeably better in the front than the older post trucks?
Thanks,
Mikel
1969 M715 6x6
1963 J300 Swivel frame
Old 01-06-2008, 11:34 AM
Can't help ya Mikel cause I dunno...but I love your avatar.
Old 01-06-2008, 11:38 AM
POST PADDER!!!!!!!
PAD...I dont know either...but you shouldnt lose a WHOLE lot but it probably will be noticable
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 01-06-2008, 11:41 AM
Mikel's Avatar
Thank you both. I made that years ago, using the gif below and adding the truck, the mud and the face wiping action. I also made the driving a bit more erratic
Didn't have a FSJ to waste my time on back then
1969 M715 6x6
Old 01-06-2008, 11:51 AM
I got the Willys....
I just had my Gladiator jacked up in the rear (one side at a time, had each side up real high I as had to drop the axle real low to swap spring pins-12" pins) causing the front suspension to flex. Seemed to flex great. Never seen my truck flex off road since I'm always the one driving it.
1971 Gladiator
Old 01-06-2008, 12:20 PM
FSJeeper FSJeeper is offline
King of Unfinished Projects
Mikel, The further out you move your springs, the less articulation you'll have to a degree. Also, the further out you move your springs the more stable you will be. I have owned both post mount trucks and late model mounts and really can't tell any difference other than the later model FSJ's drive and handle better.
Old 01-06-2008, 09:26 PM
Herk's Avatar
Herk Herk is offline
The farther out you move your springs the sooner the tires will hit them, limiting your turning radius and overall tire size. Also, you will have to move the shock out as well, causing even more trouble. Jeep moved the springs IN for a reason.
Old 01-07-2008, 04:41 AM
Mikel's Avatar
Using stock sized tires, there is more than enough room for the steering motion of the front tires. I'm not interested in large tires for this truck.
1969 M715 6x6
Old 01-07-2008, 06:42 PM
AlsChopShop's Avatar
the amount of leverage the axle will need to move the same spring in a closer to wheel position will be greater (more spring compression), meaning less flex. will you notice it? probably not.
Al
