Old 08-31-2009, 06:25 PM
onesunJ10's Avatar
onesunJ10 onesunJ10 is offline
Projekt Heavy Low J10
I've wanted to do a build thread for a while. I started the project in high school (~4 years ago) after I wrecked my first J10 at Truckhaven.
It started as a bone stock 77 J10.
It almost immediately got a simple 4in lift and some 37s. Oh how she used to be clean
In late 2006 I took it to Hollister and broke the rear Dana 44. Snapped a shaft, bent the flange, twisted the other splines and chipped some ring gear teeth. 1/2 ton stuff just wasn't up to snuff!
This was the beginning of the end. I joined the Polygoats Offroad Club up here at Cal Poly San Luis Obispo and my 1ton pipe dreams soon became reality. Hanging with these guys changed my perspectives a little bit...
My first major part of the project was the rear axle swap. Here is the thread where I did the 14Bolt swap... http://www.ifsja.org/forums/vb/showthread.php?t=60158
So. Heavy Low is born.
My 1977 J10 on 1tons and Krawlers
If you wheel on the west coast or you hit the Hammers, look for my crew, the PolyGoats: www.polygoats.com
Poundcake!
Old 08-31-2009, 08:34 PM
j20brett's Avatar
j20brett j20brett is offline
do we get the rest of the post or is this it?
Good lookin truck i just want to see the end
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 08-31-2009, 10:22 PM
RTFM's Avatar
RTFM RTFM is offline
It's an Easter egg hunt, the above thread has a link, maybe the follow on post has another link and so on.
I dig the lifted pic. Sweet.
Old 08-31-2009, 11:01 PM
onesunJ10's Avatar
That one took me awhile, got burned out tracking down pics
So, back to the build. In summer 2007 I found a Dodge 60. It needed some work.
Upgradessssssssssss \m/ \m/
Some shackles i made
Plated knucks
Broached my 30 spline flanges to 35 spline.
FORTIESSS!!
Now, for my first mistake. I will never run a long spring in the front again. I tried to run an F150 rear pack bastardized with multiple extra leafs for extra spring rate. Ultimately, these are too long, floppy, and not stiff enough. This was soon righted with a set of 52" Blazer rears. Great spring IMO.
The 57s. FAIL
Too tall with 57s
One thing that I ended up paying some serious attention to was what my ideal spring rate would be. I didnt want to screw up again. Using the idea of "ride frequencies", vehicle weight, and wheel base, I was able to come up with a ball park ideal spring rate for an dual purpose rig...(Desert prerunning/Rock Crawling). My basic frequencies were 1.2Hz for the front and 1.5Hz for the rear. My spring rate needed to be 265in-lbs. The 52s I got were 263. Pretty close. I can elaborate more on the subject, but it's too much to do so here.
Shackle reversal and plated in new front hangar....
Then there was the first ever trip to the Hammers!!
January 2008
Poundcake!
Old 08-31-2009, 11:40 PM
onesunJ10's Avatar
A cleaner picture of the rig from one year ago...
Last summer I got the axles re-geared to 5.13s and mounted some 2.5 x 14 Sway A Way "Rust" Runner shocks.
Unfortunately my comp crashed and that folder wasn't backed up. So no build pics on front shock hoops
Limit straps. The front end cycles about 13in.
I also built a front bumper.
My gussets throw horns \m/
Annnnd. New Years Hammers Trip 09. The last time she's been on the dirt.
^^Putting my driveshaft back together.
SO. Now we are almost current. I'm doing some fun stuff this summer. It's gotta be done by Sept. 11th for a end of the summer Hammers trip. Stay tuned.
Poundcake!
Old 09-01-2009, 05:59 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
Sweet rig!
Good looking fab work!
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 09-01-2009, 09:43 AM
AlsChopShop's Avatar
nice work!
i don't understand why everyone goes with grabber green though....
Al
99 Dodge 2500 4x4 - Cummins 24v
07 Mazdaspeed3 GT - Big turbo, 340whp
Old 09-01-2009, 10:38 AM
Originally Posted by AlsChopShop
nice work!
Al
Whats wrong with Grabber Green???
Thanks for the pics, your truck is an inspiration....
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 09-01-2009, 10:45 AM
Casey's Avatar
Jeep Polygamist
1994 YJ
1986 Comanche
'57 FC-150
www.cfsjc.com
Old 09-01-2009, 10:52 AM
brubakes's Avatar
brubakes brubakes is offline
I'm liking the build!
FSJless.... for now....
Old 09-01-2009, 02:11 PM
orangecherokee's Avatar
orangecherokee orangecherokee is offline
love the truck. this is something I'd like to do in the future. keep the updates coming. I'm interested in how you came up the spring rates.
Places to Wheel in the Southeast
Originally Posted by Topgun2mo
I would think boxing would limit the amount the frame could flex over obstacles which I think IMO would be a bad thing. I would think you would want all the articulation possible.
Originally Posted by johnny019
I'm not saying lockers don't improve the performance of your rig, just that they're overrated.
Old 09-01-2009, 11:20 PM
onesunJ10's Avatar
I need to talk to my buddy, as he is the one who explained the theory and basics to me. I'm missing some of the details.
But basically if you know the vehicle weight at each contact point (LF, RF, RR, LR), and you know the ride frequency you want to achieve, you can attain a spring rate that works well in most situations.
The front (mine is based on 1.2Hz) and the rear frequencies (mine is 1.5Hz) are meant to make the truck ride better at speed when the suspension is being cycled. As you drive, lets say you hit a speed bump. Your front will start to oscillate at 1.2Hz and your rear will hit the same bump 8 feet later. The goal is for the two oscillating suspension waves to match each other. You can look at is as your front and rear bumpers moving up and down at the same time. In order for the second (rear suspension) wave to catch the first wave, it must have a faster frequency. Once they are matched, the truck bounces in a much more controlled manner. However, you need to control this.
In my opinion, you need good shocks for this to work to your advantage. A properly tuned shock will dampen and control the oscillations, or bounce. I want my truck to hit a bump, oscillate once, then be back to a steady ride.
I'll post more as my memory is refreshed.
Not sure if any of this makes sense!
Poundcake!
Old 09-01-2009, 11:30 PM
onesunJ10's Avatar
Goodies.
Fred Williams old 39s
Some Rust A Ways for the rear. 2.5"x14" Piggy Smooth Bodies. I did an initial re-valve on them. Heavier rebound. It's a valve stack of .010s on both compression and rebound. We'll see how they end up working in a couple weeks.
Poundcake!
Old 09-02-2009, 09:48 AM
j20brett's Avatar
Shock pron. I love it.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-02-2009, 05:50 PM
Stuka's Avatar
Stuka Stuka is offline
Love your truck. Is that a factory color? I really like it.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 09-03-2009, 06:16 AM
mike12's Avatar
mike12 mike12 is offline
looks like a j10 or j20 or big fuggennnnn green jeep thing
LOVE THE GREEN AND TK ANT BAD
Old 09-06-2009, 03:17 PM
onesunJ10's Avatar
Finally finished my rear shock hoops. Took a couple weekends.
Cut out old cross member and shock towers.
Bent the upper hoops...
Chopped
Added a new tube near old xmember.
Mocked up.
I added a tube in between the hoops and tacked on some BA shock tabs I got from Poly Performance.
"Sure it's safe! I welder'd it myself!"
I'll snap a pic once i get the new shocks in.
Right now I'm pulling my transmission output shaft
Only 5 days til she'll be at the Hammers!
Poundcake!
Old 09-15-2009, 02:22 PM
onesunJ10's Avatar
Dovetailed J10?
So, about a month ago i started to dovetail my truck. I finished the dovetail but could never get a good look at it because the rig was backed into a corner on my sideyard. Check em out.
Poundcake!
Old 09-15-2009, 02:28 PM
trcooperone's Avatar
trcooperone trcooperone is offline
Nice work! You did a real clean job.
1976 Cherokee Chief w/401, SOA and chevy 63" springs in the back, Dana 60 in the front and Dana 70 rear welded, dana 20 twin sticked, and 38" TSL's
Old 09-15-2009, 05:32 PM
lost1's Avatar
lost1 lost1 is offline
Wow. Like others have said, nice work. I'm going to have to remember some of this stuff later on down the road.
Originally Posted by Locked and Loaded
Jeeps don't get stuck. People do.
Let the good times roll!
'83 Wagoneer«» 401/TF727/3:31 AMC20
