Intake Manifold tight end bolts.
  • Rusty76
    • Jul 15, 2018
    • 331
    Today I installed the valley pan gasket and tightened down the manifold.
    After I managed to get all bolts hand tight I started to tighten from the middle and crossing over as I worked my way to the ends. Once I got to the end bolts which are into the block it was way to hard to screw 2 of them down. I was way over spec and stopped. Currently they sit a little proud and the washer spins freely.
    Need another full turn. What to do? Leave them, tap holes, pull out the cheater bar and get it done? Thanks!
    image1 by , on Flickr
    1976 Jeep Wagoneer
    Rebuilt, 360, TH400, QT.
    Still not running. Soon!
  • Ristow
    • Jan 20, 2006
    • 17292
    run a tap thru and try. or get shorter bolts. do not force them in you will crack something or break em off.
    Originally posted by Hankrod
    • babywag
      • Jun 08, 2005
      • 10287
      Did you verify length was correct on replacement bolts?
      Agree with Ristow do NOT ever force bolts.
      • Rusty76
        • Jul 15, 2018
        • 331
        Total tunnel vision. Didn't even think about smaller bolt. I did think to maybe stack a couple washers? Anyway I picked up smaller bolt and should work thanks!
        Also something I forgot to do. A guy should probably put anti seize on these bolt?
        Also I've read about people putting a little rtv on the bolt to prevent fliuds from leaking. What do you think?
        Thanks. HAve a nice weekend.
        1976 Jeep Wagoneer
        • Ristow
          • Jan 20, 2006
          • 17292
          blind holes,nothing to leak thru. anti seize is fine.
          • Rusty76
            • Jul 15, 2018
            • 331
            Perfect thanks. I will take one out at a time and give her a little anti seize.
            1976 Jeep Wagoneer
