Any value to stock 401 pistons?
  • rang-a-stang
    • Oct 31, 2016
    • 5512
    When I do my tear down, should I be careful when removing the stock pistons from my rods or are the stock pistons worthless? Baring any damage to the piston, are they worth selling?
    Chuck McTruck 71 J4000
    (Chuck McTruck Build Thread)
    00 Baby Cherokee
  • Heavy_Metal_Thunder_81
    • Jan 10, 2006
    • 7292
    Pistons are a wear item... it'd be like selling lifters or a seal
    -Jonny B.
    AMC 401 - Pro-Flo 4 EFI
    F D44 - 4.10, Eaton E-Locker
    R M23 - 4.10, Detroit Locker
    1979 Cherokee Chief - Parts
    1979 Wagoneer - Sold
    1981 Cherokee Chief - Cubed
    • mattmopar440
      • May 17, 2007
      • 4092
      throw them on ebay if someone gives you money win win
      87' Grand Wagoneer
      80' J10 4BT/AX-15/208
      74' J10 Go Grabber Green Sold
      Originally posted by Heavy_Metal_Thunder_81
      Inferior Chevy
      • ZackN920
        • Nov 18, 2015
        • 945
        Who's gunna want to buy used pistons with "who knows" how many miles on them?
        I seriously doubt it man, but as Matt has to say... Throw em on ebay and see if some dummy buy's them!
        ...or just throw them in the scrap pile to get a little cash out of at the scrapyard.
        1990 Jeep Grand Wagoneer-"Big Jeep"
        ...in pieces for more rust repair...
        • rang-a-stang
          • Oct 31, 2016
          • 5512
          The only reason I ask is the Geo engine I built a couple years ago had these unique pistons in it. Used they were worth more than the new ones I put in. So when I did my rebuild, I had to carefully press the pins out so I could re-sell them. If these stock used pistons with "who knows" how many miles on them are worth less than $50 I'll tossem in the pile.
          On ebay they will go with a starting bid of $25/no reserve/actual shipping (providing they are not scuffed/damaged).
          00 Baby Cherokee
          • tgreese
            • May 29, 2003
            • 11682
            They can be useful for a patch-up repair on an engine with, say, a hole in one piston. There's no reason why you can't install a used piston if the diameter matches the bore and the lands and grooves are in good condition. Broken pistons are not a common problem though.
            • ZackN920
              • Nov 18, 2015
              • 945
              Really?! Well, aint that the shizzle! Never would of thought that, that would be the case with any used pistons...
              • fulsizjeep
                • Aug 21, 2002
                • 22496
                I think it is kind of funny that you expect to replace the pistons. (small haha) That decision should be made once the engine is torn down and inspected.
                • babywag
                  • Jun 08, 2005
                  • 10287
                  He wants more compression than stockers.
                  • fulsizjeep
                    • Aug 21, 2002
                    • 22496
                    Ah yes, there is that.
                    • Mikel
                      • Aug 09, 2000
                      • 6330
                      A turbo will fix his low dynamic compression problem
                      1969 M715 6x6
                      1963 J300 Swivel frame
                      • rang-a-stang
                        • Oct 31, 2016
                        • 5512
                        HAHA! I would be a liar if I had said that thought had not crossed my mind!
                        00 Baby Cherokee
                        • SJTD
                          • Apr 26, 2012
                          • 1956
                          You could run a cable through the wrist pin holes and make a dandy mirror ornament.
                          Sic friatur crustulum
                          • ZackN920
                            • Nov 18, 2015
                            • 945
                            i've seen piston paper weights and ashtray's too.
                            • rang-a-stang
                              • Oct 31, 2016
                              • 5512
                              At work I keep my change in a piston that I had in one of my VW engines. I sucked a valve, broke the head off it, and jammed the head of the valve back into the exhaust port sideways. Some cool markings on the top of the piston.
                              00 Baby Cherokee
