Hi, I'm still trying to figure out my rough running/stalling TBI. I rewired the computer and some burnt wires under the hood. It looks like my voltage is stable again. Could anyone take a look at the logs and give me some pointers?
More TBI log help
From what I see, the TPS isn't adjusted correctly.
It's dropping to .2v which is too low.
If you didn't perform the initial setup, you need to do this.
I know the first thing guys want to do when hooking up their fuel injection set up is to start it up and hear it run.... Well there are a couple things that need to be done after the installation. Note: When setting the timing for the first time you must ensure the wiring is correct on the...
And common sense dictates verify no vacuum leaks, and fuel pressure is good.
Lots of knock counts, are you using a knock sensor?Tony
I bought the Jeep with the setup but the distributor was changed by the mechanic, so I will try resetting everything from scratch. I'm not sure what the knock sensor is picking up because it doesn't sound like that.Marvin -- '87 Grand WAGONEER, Big Lift, Big Tire
Bob -- '89 GW, No lift, No tires
There's a reason some suspension bolts have MF on them.
What would cause low compression all on one side, cam shaft issue?
Originally posted by babywagyeah not good...
do a leakdown test and see what exactly is going on.
or just pull head since all low ones are on same side?Marvin -- '87 Grand WAGONEER, Big Lift, Big Tire
Originally posted by spyderkeeperI bought the Jeep with the setup but the distributor was changed by the mechanic, so I will try resetting everything from scratch. I'm not sure what the knock sensor is picking up because it doesn't sound like that.* 1981 stepside, 360, 727, 208, almost stock daily driver.
