-   General FSJ Tech (http://www.ifsja.org/forums/vb/forumdisplay.php?f=10)
-   -   kudos to Edelbrock (http://www.ifsja.org/forums/vb/showthread.php?t=35834)
AMX factor 04-17-2004 03:09 PM
Yes big pat ont he back for the Edel boys. Nice day here in Denver and I spent it installing my Edelbrock TES headers. Started at 8 am by 10:30am I had the original exhaust system dropped, both exhaust manifolds pulled and the driver's side header bolted up. They are easier to install than the instructions lead you to believe. Granted it was nice that I started adn put the first wreench to the original manifold bolts I found them all easy to remove. I didn't have to dig out the PB Blaster as I fear might happen. At the end of the day I have both headers installed, Y-pipe in place all plugs replaced wires reattached, added 1" spacer to carb and fired it up. Loud as hell due to open header pipe, HOA pissed again. Tomorrow I'm going to throw a a single 3" cat and muffler in place to get me to work next week then I'm headed to the exhaust shop where they will fab new header pipes to make a dual exhaust system with H-pipe. I'll post pics as I am making a dual exhaust system with both pipes, cats and mufflers on the same side and tucked between the frame and the driveline and not lower than the frame. If you ever have the money to get an Edel exhaust they are worth it. Of course a good used set is even better!
Bobby88GW 04-17-2004 04:00 PM
Will the headers accept air tubes?Curious.
bigun 04-17-2004 04:05 PM
This post is worthless with out Pics j/k
jgarcia2 04-17-2004 06:08 PM
Man, this group is amazing... Just when I think I'm going to have to figure something out for myself, someone else is a step ahead of me!
AMX Factor, please keep us informed of the process. I just bought the Edel TES headers and am glad to hear they installed easily. Now, how are you routing your dual exhaust, and how much is the exhaust shop work going to cost? I want to do basically the same thing.
Gosh, I could keep going...Anyway, a cost estimate would be awesome!
Thanks,
John
AMX factor 04-18-2004 01:54 AM
bigun - I'll get you some **** pics!
The headers have air tubes on them as they are California CARB legal.
jgarcia2 - I'll be posting finished pics of the system. I'll try and send you a drawing of how I'm doing the one sided dual exhaust. Key thing is the mufflers. I bought Walker Dynomax Turbo Tubes. They are like a cherry bomb except a turbo. There are 3 sets on ebay right now for sale. I went with 24" for room and good sound. I've gotten 2 estimates to finish the system. Basically I need straight tail pipes with a bend to clear rear bumper and new head pipes from headers to cats. One shop wanted $500 which is outrageous comsidering I've done 85% of the work and all he has to do is make make head pipes, another shop said $150 at most.
TexasJ10 04-18-2004 03:30 AM
Are the TES headers are the new shorty headers? If they are, I thought the original y-pipe was suppose to connect directly to them. Is it the pre 1980 y pile of the 1979 and before y-pipe that connects these. I know, I know, way too many questions!
AMX factor 04-18-2004 03:56 AM
No the TES, Tubular Exhaust System is the original Edel headers. The TES comes with a new Y-pipe. No idea on the 79-80 Y-pipe. The TES is about $50 cheaper($510) than the Shortie headers($560) that are yet to be released.
jgarcia2 04-19-2004 03:01 PM
AMX factor, you are getting me all hot and bothered here. I would greatly appreciate the plans. Keep us informed!
I can't wait!
Man, that's quite a difference in price quote...I guess it pays to shop around.
cammobus 04-20-2004 07:51 AM
to clarify the TES dumps into a 3" Pipe ?
and when are you going to put on the RPM Al Heads ? heheheh ;)
and yeah where are the pics
AMX factor 04-20-2004 09:20 AM
The TES dumps into a 2-1/2" y-pipe.
jgarcia - diagram coming
cammobus 04-26-2004 11:38 AM
so how is that UAV Running with the new Exhaust now .....
AMX factor 04-26-2004 12:45 PM
The UAV is now quite scary and moves very well. Hoping to add the other exhaust next weekend running the single right now. Gonna do a spring trail run Sunday. Should rattle the rest of the dead leaves outta the trees.
cammobus 04-26-2004 01:26 PM
Glad to hear ......... my 87 GW is in need of exhaust - so i am thinking of this upgrade as well ... please explain the other exhaust ? r u converting to dual or are you refering to the rest of the setup, after teh Cat ?
AMX factor 04-26-2004 03:06 PM
I am refering to the other side of my dual exhaust. I only have one complete system on right now to get me thru emissions testing then I am adding the other half with adn H-pipe. Basically I have to ditch the Edelbrock Y-pipe and build new head pipes. It will all fit along side of itself on the passenger side of my GW.
1BDWAGN 04-27-2004 01:42 AM
Pictures are nice but we want to hear how it sounds when it is done too.
cammobus 04-28-2004 02:15 PM
OIC - Single Pipe ........ OUCH 500 and your only using the headers ........
jgarcia2 04-30-2004 07:05 PM
AMX Factor, thanks for the diagram. Definitely anxious to see how it works out for you! I have a big box of TES headers in my house now (my wife hates me). Oh the're so nice!!
Good luck,
John
cammobus 04-30-2004 11:54 PM
1BDWAGN - Try this for size :
:D
Exhaust Sounds
1BDWAGN 05-01-2004 07:06 AM
Thanks for the link cammobus. Although I was hoping to hear what it sounded like on an AMC V8. I don't think I heard one that has been warmed up a little yet.
cammobus 05-01-2004 09:25 AM
probably - but they sound great just the same ....
